Laser not reading new bed dimensions
Hi, not sure where I should be asking this question. I havean Ortur Laser Master 2 with Lightburn. I added bed extender and the laser wont read the new bed settings. In fact after changing the settings and having issues I reverted back to original settings and now the laser will only move about 100mm on the y axis. I changed settigns on the console and the Device Settings to no avail. I am not very tech savvy so please excuse my ignorance. I did use the laser with success on a couple project before extending the bed.
This is not possible. Your controller can´t know that you altered your hardware unless you cange the settings in lightburn.
You have changed what in which menu? You only need to alter with and heigh in device settings to the new values.
You have changed what parameter in console to which value? In any case, you can´t alter bed size there. Only $130, $131 have to be adapted if there is set a soft limit alarm.
Seems you not have reverted all setings to the original value.
Here is a link to the values and their meanings:
https://github.com/gnea/grbl/blob/master/doc/markdown/settings.md
