Ok, please bear with me here. I am fresh as fresh comes with this and all was going so great last night when I set it all up I was so stoked…to wake up this morning, turn everything on and BAM issues.
I am trying to frame my laser for proper blank placement on the board/plate. This worked fine last night. I did go in and change one setting from default last night and that was “Add Fire Button” so I could see where my laser is. Other than that everything should be default. This morning I turned on my laser and Lightburn was already running. I started a new project (just some generic text to be able to keep learning this) and now when I hit home it went to the bottom left once but now it doesnt go “Home” any more. I hear the fan kick on so it’s talking to the laser. I try to use frame and it would just like click, but not frame (framing worked last night). When I hit frame a second time, a timer begins to count up in the LASER control box on the bottom right of my program (I will attached a screen shot once I figure out how). In my CONSOLE control box I am getting errors and code like text I don’t understand. Can anyone help? This all worked last night for a small test burn and the only issue was I had almost like a double image. I was going to work on figuring out how to tighten up the lettering so I can make my final project. Any help is appreciated thanks!!
I am running an Ender 3D Pro with a CV Laser Module
Windows 11 Pro on desktop
CONSOLE box shows
ALARM:3
Reset while in motion. Grbl cannot guarantee position. Lost steps are likely. Re-homing is highly recommended.
[MSG:Pgm End]
ok
e[0;31mE (985048) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (985049) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (985050) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (985052) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
spindle_pwm_off_value:0.000000 spindle_pwm_min_value:0.000000 spindle_pwm_max_value:1023.000000
Grbl 1.3a [‘$’ for help]
[MSG:‘$H’|‘$X’ to unlock]
[MSG:Caution: Unlocked]
ok
Waiting for connection…
e[0;32mI (1592922) serial: Line state changed! dtr:0, rst:1e[0m
e[0;32mI (1592963) serial: Line state changed! dtr:0, rst:0e[0m
e[0;32mI (1594217) serial: Line state changed! dtr:0, rst:1e[0m
ok
ok
Homing
e[0;31mE (1594668) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (1594669) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (1595390) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (1595391) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (1595392) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (1595394) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
ok
e[0;32mI (3177270) serial: Line state changed! dtr:0, rst:1e[0m
e[0;32mI (3177321) serial: Line state changed! dtr:0, rst:0e[0m
e[0;32mI (3178473) serial: Line state changed! dtr:0, rst:1e[0m
ok
ok
Homing
e[0;31mE (3178917) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (3178918) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (3179564) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (3179565) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (3179567) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (3179568) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
ok
<Idle|MPos:3.000,3.000,0.000|FS:0,0|WCO:0.000,0.000,0.000>
ok
Starting stream
Stream completed in 0:00
<Run|MPos:119.700,3.000,0.000|FS:20,0|Ov:100,100,100|A:S>
ok
Starting stream
error:8
Grbl ‘$’ command cannot be used unless Grbl is IDLE. Ensures smooth operation during a job.
error:8
Screenshot of my settings:
