Laser off work space
i have an Ortur Laser Master 2
This is driving me mad! The pictures may or may not help.
The bed is 400mmx430mm, home is near left corner.
On start, the laser moves to this position. I open a file or place some artwork on the workspace. In “Arrange” I choose move artwork to laser position and as the photo shows, it moves the artwork off the workspace.
The GRBL settings shows the workspace as 400x430. GCode shows it as -375x-375. Is this what is causing it or is it something else? If it is the cause, how do I change the GCode?
None of your pictures seem to have uploaded correctly.
Based on what you’re saying it’s likely that you somehow have an offset wofkspace configured.
Can you run a homing cycle and then immediately following run these commands in the Console window and copy all output from that window here?
$I
In the console, type this command:
$RST=*
(and press enter)
Then change your ‘Start From’ setting to ‘Absolute Coords’ and things should be working correctly for you.
Please follow the instructions from Oz. However, after doing so, it’s possible that not all of your issues will be fully resolved as I’ve seen the reset not restore some of the things you’re dealing with.
Test and if problems persist plesae follow the instructions from my previous post. Instead of a photo, please copy and paste the output from the Console window into a post.
I did as you instructed. It worked for one pass. I decided to play with a longer thing to see what would happen. Now the laser stays on for literally 2.5 seconds.
This is what comes up when it stops…
Project loaded in 40 milliseconds
Starting stream
Layer C01
error:1
G-code words consist of a letter and a value. Letter was not found.
On or near line 0:
Job halted
Stream completed in 0:0
G-Code is now…
[G54:0.000,0.000,0.000]
[G55:0.000,0.000,0.000]
[G56:0.000,0.000,0.000]
[G57:0.000,0.000,0.000]
[G58:0.000,0.000,0.000]
[G59:0.000,0.000,0.000]
[G59.1:0.000,0.000,0.000]
[G59.2:0.000,0.000,0.000]
[G59.3:0.000,0.000,0.000]
[G28:0.000,0.000,0.000]
[G30:0.000,0.000,0.000]
[G59.6:0.000,0.000,0.000]
[G92:61.987,-327.263,0.000]
[HOME:0.000,0.000,0.000:0]
[TLO:0.000]
[PRB:0.000,0.000,0.000:0]
ok
Let’s get rid of that G92.
Do this after you home the machine.
G92 X0 Y0
Retest and report back.
$0=5.0
$1=5
$2=0
$3=2
$4=0
$5=7
$6=1
$10=2047
$11=0.050
$12=0.002
$13=0
$14=2
$15=0
$16=1
$17=0
$18=0
$19=0
$20=1
$21=1
$22=43
$23=7
$24=600.000
$25=3000.000
$26=100
$27=3.000
$28=0.100
$29=0.0
$30=1000.
$31=0.
$32=1
$33=1000.000
$34=0.000
$35=0.000
$36=100.000
$37=0
$39=1
$40=1
$41=0
$42=1
$43=1
$44=3
$45=3
$46=0
$56=1.000
$57=1800.000
$58=395.000
$59=6000.000
$60=0
$61=0
$62=0
$63=3
$64=1
$65=0
$259=0
$260=70
$261=70
$262=290
$263=30
$264=0
$100=80.000
$101=80.000
$102=80.000
$110=10200.000
$111=10200.000
$112=1200.000
$120=2200.000
$121=1800.000
$122=2200.000
$130=400.000
$131=400.000
$132=50.000
ok
This is the GBRL as of now.
[G59.6:93.988,139.463,0.000]
[G92:93.988,139.463,0.000]
[TLO:0.000]
ok
This is the G Code. It will run longer now but still shuts off without completing. I did type in the G92 x0 y0 but it did not change the values to zero, but it changed the numbers,
Thank you for your help by the way!!!
Position issue is resolved. The workspace and laser are both where they should be.
There’s a regression in the offsets vs the previous correction. Are you running laserGRBL and setting origin from that program?
Run these commands in Console. Copy and paste these instead of trying to hand enter.
G59.6 X0 Y0
G92 X0 Y0
Power cycle the laser and then rerun:
Did something change between this post and the previous one or was this more information?
We are back to negative workspace again.
G59.6 x0 y0
G92 x0 y0
ALARM:9
Homing fail. Could not find limit switch within search distance. Defined as 1.5 * max_travel on search and 5 * pulloff on locate phases.
Ortur Laser Master 2 Pro Ready!
OLF 170.
[MSG: Flame detector active,Ambient infrared value:0]
Grbl 1.1f [’$’ for help]
[MSG:’$H’|’$X’ to unlock]
[MSG:Caution: Unlocked]
ok
[TLO:0.000]
I don’t think I will get back to this before tomorrow so bear with me. I still have some time left this morning but you may not.
Are you copying and pasting the commands into Console? Not sure why those aren’t taking.
Take a look at this post. Follow the instructions carefully.
Check $# after running.
Definitly the above
And also
https://ortur.tech/firmware/OLM_Series/OLM2_PRO_S1_Firmware_Release_1.75.zip
[G92:0.000,0.000,0.000]
[HOME:0.000,0.000,0.000:7]
[TLO:0.000]
ok
Now I am going to cut the power way down and see if the thing will actually run. Fingers crossed. Workspace and laser position are correct.
Laser STILL will not run through the entire cycle!
This is the message that comes up.
<Idle|MPos:149.263,145.525,0.000|Bf:15,1022|FS:0,0|Pn:PS|CL:0,100|PS:2,1|ER:0,0|VA:22249,0|Ov:100,100,100|A:S>
[HLP:$$ $# $G $I $N $x=val $Nx=line $J=line $SLP $C $X $H $B ~ ! ? ctrl-x]
ok
ok
These are the grbl settings
$0=5.0
$1=5
$2=0
$3=2
$4=0
$5=7
$6=1
$10=2047
$11=0.050
$12=0.002
$13=0
$14=2
$15=0
$16=1
$17=0
$18=0
$19=0
$20=1
$21=1
$22=43
$23=7
$24=600.000
$25=3000.000
$26=100
$27=3.000
$28=0.100
$29=0.0
$30=1000.
$31=0.
$32=1
$33=1000.000
$34=0.000
$35=0.000
$36=100.000
$37=0
$39=1
$40=1
$41=0
$42=1
$43=1
$44=3
$45=3
$46=0
$56=1.000
$57=1800.000
$58=395.000
$59=6000.000
$60=0
$61=0
$62=0
$63=3
$64=1
$65=0
$259=0
$260=70
$261=70
$262=290
$263=30
$264=0
$100=80.000
$101=80.000
$102=80.000
$110=10200.000
$111=10200.000
$112=1200.000
$120=2200.000
$121=1800.000
$122=2200.000
$130=400.000
$131=400.000
$132=50.000
ok
Found the settings for the USB time out, disabled them and now this is the error message
ok
Starting stream
Layer C01
error:1
On or near line 0:
Job halted
Can you go to Edit->Device Settings->Gcode tab and make sure you have nothing entered into those boxes? Take a screenshot and then delete anything that’s there. Please upload screenshot here.
Where did you make this change?
Setting for USB time out is under control panel, hardware and sound, power options.
LORD help me!!! This may have worked
I erased the code that was under the G Code additional settings. The laser ran through an entire project so it may be fixed! Once it warms up a little here, I will go outside and give it a true test.
Asset 1
First and foremost…The dang thing works! But why will it not start in the correct place? I just allowed it run its cycle and hit start when it finished. I almost bet there is a grbl setting that I am missing or I messed up.
So very thankful to you all for getting me up and running again.
Likely not a GRBL setting at this point.
Most likely something mechanical. Or, if you homed again between cycles it will almost certainly be misaligned at least slightly. Though this looks a little extreme.
Make sure your belts are properly tensioned. Make sure there’s no slack and taught but not stretched.
