Laser on/off when moving $31-1 NOT working
Tried everything and read everything. Laser is not pausing/stopping, drag markings in between all moves. I installed a new power supply thinking this was the issue and still the same. What else can I try? Is there any other software tweeks in lightburn I can change? Using a Awesometech MG3 in the K40 and have this issue, could it be a bad MG3 controller? VER1.1f.20211209;
So what I discovered is if I use GRBL-STL I have this problem with the move marks.
If I use GRBL-M3 (1.1e or earlier) Lightburn works with no move marks, laser turns on and off as it should. But I cannot manually move the laser with the move function or home it.
Is this a Lightburn issue or an Awsome.tech MG3 board issue.
Assuming that note applies, then use GRBL-STM.
If they look like those in the Troubleshooting guide and you’ve set $32=1 and you have verified that change is applied, then go through the steps they recommend:
If those don’t improve the situation, then we’ll need all the details of the actual wiring if it differs from the MG3 installation instructions to provide more help.
