Laser only firing at lower Power -
Has anyone ever had an issue where the laser only fires at lower power. As soon as the power goes above 50%, the laser does not cut. Although I can see tube firing, the output is drastically reduced. This % seems to keep on reducing, yesterday I could cut at 60%, today not.
New mirrors, and alignment is perfect.
If the tube is bad, what might have caused this - I did recently change the power supply, cause it made a bad noise, and the current was spiking. I suspect the tube is lost to humanity. Just need some inside before I buy a new tube.
Thank you.
This post describes a tube test:
Show a picture of the scorch mark at the tube exit and we’ll know more about what’s going on.
