Laser only makes frame travel, then nothing more
Hallo,
ich habe den Elegoo Phecda. Nach dem kauf ging er auch ohne Probleme mit der Testversion von Lightburn. Nach Auslaufen der Testversion habe ich die normale Version gekauft uns seitdem geht nichts mehr. Rahmenfahrten sind ohne Probleme möglich, doch dannach kommt das: Auf Verbindung warten …
Hello,
I have the Elegoo Phecda. After purchasing it, it worked perfectly with the trial version of Lightburn. After the trial expired, I bought the regular version, and since then, nothing’s worked. Frame runs are possible without any problems, but then this message appears:
ok
Summary
[V4.00(8M.H35.20240320)]
[VER:1.1h.2024032001:]
[OPT:VMPH,63,256]
Target buffer size found
[MSG:Using machine:MKS DLC32]
ok
[MSG:Mode=AP:SSDI=MKS_DLC53397:IP=192.168.4.1:MAC=D8-BC-38-42-95-D1]
ok
Projekt in 10 Millisekunden geladen
Stream wird gestartet
Stream completed in 0:00
[MSG:Mist coolant on pin GPIO(19)]
E (1038) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first
E (1041) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first
Grbl 1.1h [‘$’ for help]
ok
[MSG:WiFi Off]
ok
ok
[OPT:VMPH,63,256]
ok
[MSG:No Wifi]
ok
ok
ok
[MSG:Local access point MKS_DLC53397 started, 192.168.4.1]
[MSG:HTTP Started]
[MSG:TELNET Started 8080]
[HLP:$$ $+ $# $S $L $G $I $N $x=val $Nx=line $J=line $SLP $C $X $H $F $E=err ~ ! ? ctrl-x]
ok
$54=12345678
$53=MKS_DLC
$52=12345678
$51=MKS_DLC
$0=10
$1=25
$2=0
$3=7
$4=0
$5=1
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=0
$23=5
$24=300.000
$25=1000.000
$26=250.000
$27=1.000
$28=1000.000
$30=1000.000
$31=0.000
$32=1
$41=1
$47=1
$46=1
$102=100
$101=80
$45=0
$44=0
$43=1
$42=1
$50=1
$40=1
$100=80.000
$103=100.000
$104=100.000
$105=100.000
$110=25000.000
$111=18000.000
$112=6000.000
$113=1000.000
$114=1000.000
$115=1000.000
$120=1000.000
$121=300.000
$122=500.000
$123=200.000
$124=200.000
$125=200.000
$130=400.000
$131=400.000
$132=50.000
$133=300.000
$134=300.000
$135=300.000
ok
ich habe an den Einstellungen nichts geändert und verstehe nicht, warum er plötzlich nichtmehr geht.
I haven’t changed any of the settings and I don’t understand why it suddenly stopped working.
Da sind zwei Ausgaben drin, die eher auf Firmware-Fehler hindeuten, zumindest eventuell. Ich würde als erstes noch mal die Firmware beim Hersteller runterladen und den Laser neu flashen.
Leider ohne Erfolg :frowning: Firmeware ist aktuell und richtig aufgespielt. Er hat ja schonmal geklappt und seitdem wurde von mir nichts geändert. :frowning: Neues Motherboard habe ich bereits bekommen, ohne Erfolg. Es bleibt bei der Meldung:(
Das heißt nichts. Die Firmware sollte noch mal drüber installiert werden. Vorher kannst du noch mal mit dem Kommando $RST=* in der Konsole die Einstellungen auf Werkseinstellungen zurücksetzen.
Wenn der Rahmen normal geht, aber danach nicht, würde danach die Air Assist-Pumpe starten? Das deutet dann auf ein defektes Netzteil hin.
That means nothing. The firmware should be installed again. Before doing this, you can reset the settings to the factory settings using the $RST=* command in the console.
If the frame works normally but not afterwards, would the Air Assist pump start afterwards? This would indicate a defective power supply unit.
Das wurde bereits mehrmals gemacht (die Firmware neu aufgespielt)
Der air Asisst sitzt extern und muss manuell zugeschaltet werden. Der Laser selbst weiß nicht ob der läuft oder nicht. Egal ob mit oder ohne es geht nicht. Das komische ist ja, dass der Laser BEVOR ich Lightburn gekauft habe ja mit Lightburn lief. Erst nach dem Kauf trat das Problem auf
LightBurn ändert keine einzige Funktion durch die Lizenz. Daran kann es nicht liegen. Aber es kann durchaus mal ein Bug auftreten. Ich würde zwei Sachen probieren: über das Menü kann man alte Einstellungen laden, wenn du da noch ein Backup (wird automatisch erstellt) von vor der Änderung hast, dann lade das rein und probiere, ob es dann geht. Falls nicht, LightBurn komplett löschen, auch sicherstellen, dass keine Backups und alte Verzeichnisse übrig sind, und dann noch mal neu installieren.
