Hey I run a snapmaker artisan and everything works fine except if I add multiple objects / layers to my project. The laser moves to all layers properly but only turns on the laser at the first layer.
Hello Oliver
There is a quick test you could do - but not sure it would work
Edit > Device settings
Gcode Tab
Toggle on Emit S value with Every G1 command
Then try again engraving pelase.
Also make sure you are on GRBL - and not GRBL LPC
