Laser Pecker 4 framing laser won’t frame around the work area since I updated to 2.1
I am using the laser pecker 4 and since I updated the software in lightburn to 2.1 my framing laser won’t gram the work space . I installed the patch but still doesn’t work. The dialogue box comes up as if it’s working but I don’t see it framing the work. I have the laser brightness way up., I also turned on continuous framing and I turned oh firing laser.
Not sure what else to try.
As a start check the device, control, design Units maybe something has changed:
Also try loading a prefs file from when it worked:
I tried all that including reverting back to early may version when it was working. Still not framing the work. The window shows up saying it’s framing but the laser dot doesn’t move.
