Hi, for what is the Laser Offset setting in the Device settings?
In the online documentation is nothing written about, also you have a very old screenshot in there.
If you have a red-dot laser pointer that is parallel with the laser head, that offset controls the distance between the frame and cut. It lets you shift the cuts to align with the dot.
only the cuts or also the engraving/fill elements?
Everything. It offsets the entire job by the amount entered.
