Laser power is much less then light burn says
Edit > Device Settings > S-VALUE MAX = 1000
see if yours is like this.
Yes it is is that a good thing or a bad thing
I think this is what @LordSangreal is trying to convey…
check your lens you could have a cracked lens. It is happened to me before I was working fine and then could not get a decent cut and it was because the liens need cleaning or was cracked. It happens.
I don’t know why so many people have this set to 1000 by default. I have a 5.5W laser and this value needs to be set to 10000, for me. That’s ten thousand not one thousand. You should give it a try.
My Laser engraver also has a spindle for CNCing. That setting is in the board as 10000 for the CNC spindle max rpm. Instead of changing it whenever I use the laser module I just change it in LightBurn software to match, 10000.
It’s very unlikely that you need a value other than 255 or 1000. Not saying it isn’t possible, but very unlikely for the majority of diode machines out there. The vast majority use 1000.
I’d advise you import the .lbdev file for your D1 as per xTools instruction page here: https://support.xtool.com/hc/en-us/articles/4414120232983-User-Manual-for-xTool-D1-LightBurn-Software
