Laser Preview, and more questions
Hello,
First of all, I’m very happy with the Lightburn, but I still have a few questions.
Is there somewhere you can activate a preview laser when showing the frame? I heard you should press Shift while clicking on the frame, but unfortunately nothing happens.
Is there the possibility, like with LaserGRBL, that you can start an acoustic countdown when you press start? I think it’s almost dangerous if you accidentally click Start instead of the frame and just expect a frame movement that triggers the laser without prior notice. Here I would like to see an acoustic signal followed by a 5 second countdown, or a warning that you have to acknowledge before the laser is activated.
Greetings! Max
If you enable job check list in device settings (reminder to focus or whatever) you have to click ok before the job starts. May be what you are looking for.
No beeping or anything, but you do have to click before it starts.
Will still frame, but not start.
as @Bikemike said but visual edition
Make sure these 2 settings are on.
Make sure you set your power at 1% roughly here:
The countdoun is not possible
However you can enable (Device settings) Enable Job Check List
This should at least give you a prompt
Thank you all for the answers, that was exactly what I was looking for.
Greetings!! Max
