Okay I know that this china laser is junk but I haven’t given up. I had it working a few days ago. And today, I tried turning it on and nothing is working. it keeps saying the “settings are disabled” anybody know what this is about?
Waiting for connection…
Grbl 1.0b [’$’ for help]
Your Grbl may not support Variable Power mode (M4)
If your laser does not turn off between cuts,
switch to the GRBL-M3 device
Homing
error: Setting disabled
Starting stream
Stream completed in 0:00
Homing
Homing
QF�
Homing
Homing
Homing
$0=10 (step pulse, usec)
$1=25 (step idle delay, msec)
$2=0 (step port invert mask:00000000)
$3=0 (dir port invert mask:00000000)
$4=0 (step enable invert, bool)
$5=0 (limit pins invert, bool)
$6=0 (probe pin invert, bool)
$10=3 (status report mask:00000011)
$11=0.010 (junction deviation, mm)
$12=0.002 (arc tolerance, mm)
$13=0 (report inches, bool)
$20=0 (soft limits, bool)
$21=0 (hard limits, bool)
$22=0 (homing cycle, bool)
$23=0 (homing dir invert mask:00000000)
$24=25.000 (homing feed, mm/min)
$25=500.000 (homing seek, mm/min)
$26=250 (homing debounce, msec)
$27=1.000 (homing pull-off, mm)
$30=1000. (rpm max)
$31=0. (rpm min)
$32=0 (motor lock bool)
$33=7 (motor mode mask:00000111)
$100=80.000 (x, step/mm)
$101=80.000 (y, step/mm)
$102=80.000 (z, step/mm)
$110=10000.000 (x max rate, mm/min)
$111=10000.000 (y max rate, mm/min)
$112=10000.000 (z max rate, mm/min)
$120=250.000 (x accel, mm/sec^2)
$121=250.000 (y accel, mm/sec^2)
$122=250.000 (z accel, mm/sec^2)
$130=500.000 (x max travel, mm)
$131=500.000 (y max travel, mm)
$132=500.000 (z max travel, mm)
ok
$H
