Laser seems to not be working at full force
I have only had my laser for a month, and everything was working great until recently. My laser seems to have stopped firing at full force. I have to slow the speed down to 50 (instead of my normal 1200) to even see a mark on the wood.
If I set it to line I have a better result, but when it is set to fill, it doesn’t seem to get hot enough before it passes over. I attached a picture of a project I was trying to do. You can see the laser burs through fine at times, and did not even burn through the tape in other places.
Any idea how to fix this?
50 what? mm/sec? mm/min? inches/sec? parsecs/fortnight? (check to make sure you are in the correct units)
