I am etching small wooden boxes and after a few minutes into the etching the laser shuts off but the machine keeps moving. I took out the box lids and put a scrape piece of wood and the laser etches the image. when I place a new box lid and hit start the etching goes for a few minutes and shuts off.
I have ruined two box lids and I cannot figure out what I am doing wrong. I have the same settings on the scrape wood as I do the box lids. I have a x-carve 1000mm with j-tech 7w laser
Are you suggesting that the simple act of changing the substrate you are burning has the effect of turning your laser off? This is not possible. The laser knows nothing about what you are wanting to burn. There has to be something else going on and your observation is a coincidence.
Do you happen to be using a USB extension? Do you have a sleep of the USB ports as part of energy savings settings in your OS? Is this a large picture where the laser could be overheating after several tries and that is the coincidence? I am now just guessing…
What power settings are you using for the engraving?
Watch the tube when it stops working. Is it lighting?
Check the tube. Is it hot? Might be warping.
