When I set the laser speed with a value less than 3000 mm/min, the laser only works at the max or the min power, no intermediary power…
I have to set the speed with a value equal or greater than 3000 mm/min for the laser use intermediary power steps between the max power and the min power.
The issue persists…
If speed is set to a value lower than 3000 (mm/min) laser only works with max or min power…
When I set speed to 3000 (mm/min) laser power assumes intermediary values between min and max power.
Already set $30=1000 and $32=1…
Any other suggestion?
Thanks!
I’m using the firmware provided by the seller of the controller board: MakerBase MKS DLC32 v2.1 (December/21 update).
GRBL Machine
I’m sending attached the project file. Yoda.lbrn (1.7 MB)
The display connected with the controller board shows that the signal power is 0 or 200, when using LightBurn.
When I use the same parameters with LaserGRBL (min power = 0, max power = 200, speed = 1500) the display shows a wide range of intermediary signal values between 0 and 200.
LaserGRBL engraves the image with good quality.
