I have been running my Sculpfun 9S for the past few years with lightburn and had no problems until the last up date 2.1.03. I am using a HP laptop which has never been a problem before. As I haven’t been in the workshop for a few weeks this problem has just come to light.
For some reason all my pre-set cut setting have set them selves to 63.33 speed and 60 power. which has never happened before. the second problem is I have no control over the speed of the laser, it only runs at the speed as if it was framing a job even if I change the speed on the panel. Every other function runs ok. I’m running out of settings to check, the power setting seems to be ok as I ran a quick Squair patten to check and could smell burning wood on the bed.
Thanks for that pointer, I have checked all those settings and they are all set correct, but I still have no control over the laser head, it still runs at framing speed.
I may not have understood your problem correctly, can you try to direct me closer to the problem?
Are these the speeds in general for all laser operations or are they the movement speeds when framing your laser head?
Can you show your settings?
Thank you for your suggestion, I have been over my settings and found the problem, sometimes you can look and look and still miss something. Back up and running now thank you.
