Laser starts fire while cutting
Hey everyone,
Can anyone tell me what is happening with my laser. Its just 2 months old, I didnt work much with it.
I have Sculpfun S30 33w. I use same material all the time. On begining it worked very well, there were almost no burns at all.
2 weeks ago I dont know what happened but laser starts fire while cutting material.
So, long story short:
Material - mdf 3mm coated (material is same all the time so material is not problem)
Focus - checked with metal tube that comes with laser
Lens - changed, new one
Cutting speed - 450mm/min
Power - 80% (never went above that)
Passes- 1 pass
Air-assist - original sculpfun… its always on or it would be real fire
Engraving is great, no problems with that… I engrave on 5000mm/min speed and 70% power… If making sufrace lines I set 2000 mm/min and 70% power and then there is no trace of any burn…
(same result is when I put higher speed and more passes, for example 1250mm/min and 4 passes)
Link of 3 videos below
Thank you in advance
One more video
No material is the same. They can have changed the glue type, the coating type etc. The material still can be the reason.
Too slow. Never cut below 600 mm/min, for the 33W I recommend never cutting below 1000 mm/min.
Increase according to speed increasement, e.g. 1200 mm/min - 3 passes.
What I saw in the video looked like turbulence from the laser cooling fan. It did not look like the nozzle was ejecting air.
Reduce power to 0.5%, run a test, and pull the air assist off the nozzle and check for air pressure.
It worked well for 2 months at that speed…
Even 2500mm/min and 7 passes leave huge burns…
Yes, true… When I put my hand near laser its like I put hand through car window (very windy)… What is solution for that… ??? On burns I can see air direction… sometimes its inside burn, sometimes outside…
Are you sure your laser is focused correctly?
By focus you mean distance from material ?
Yes. You can get some burning because the laser is out of focus.
Yes, focus is ok. I have metal tube from sculpfun that i put under laser for measure so it cant be wrong…
Have you cleaned your lens?
yes. I clean lens before every start… this is new lens actualy… i dont use machine often… maybe 3 times per week, total 5 hours… small projects mostly
