Hello, I have a problem, that my laser connected with the software an shows also the rame, but when I start the process for laser it goes to the start point and the laser stays at the point and laser the whole time ona the same area/this point only at this position and does not move.
Please could someone help me?) Also in German or English)
I need the laser to end my modelling for the university.)
I have had similar issues where the laser burns a hole instead of drawing lines. I use one or both of the following to overcome that issue. my laser is Ortur Laser Master Pro 2
Use a different speed - in stead of 1500mm/min, adjust to 1550mm/min
Don’t start the burn from HOME location - use the FRAME first, then start the burn without going back to home.
Try those and let us know it if fixes the problem.
