Laser Stays On Between Cuts - No Access To Console
Hi,
I have a Lotmaxx Shark V2 3D Printer/Laser Engraver combo. Lightburn won’t detect my printer so I’m just designing, saving the Gcode, and uploading via octoprint. I know the “laser staying on” topic has been covered many times but since I can’t connect to my printer, the Console doesn’t populate with anything so I cant change $32 to 1. I have tried every device on the list and the GRBL profiles are the only ones that give me any results.
Any help is much appreciated.
How do you currently change the firmware settings on this device?
There is an SD card that contains the firmware settings via a configuration text file. But it seems to be fairly rudimentary.
What firmware are you using to drive the motion control board?
