I was working on a job and the machine beeped that it was done and as i was opening the lid to remove the work i noticed that the laser stopped firing mid work?
Laser is a 100w ruida 644x board.
I have 2 of these and the the bottom 2 red lights are not “on” on the other machine. Pulse fire works fine. I have a feeling its the water sensor possibly? any thoughts?
anything else in comparison between both machines looks no different as far as what lights are on.
The power supply is covered with dust from the cutting and it looks like it burnt out one of the power jump things? I ordered a new power supply already hopefully that is the issue and ill be covering the electrical side with tape or something to keep dust away from that area.
Mine machine is apart, but I’ll check it when I get it back up… I don’t believe it sits on the switches. And agree, doubt it’s an issue to worry about at this point.
Just for kicks I cleaned up the power supply and now it’s shorting lol🤦🏽♂️
I spoke with my vendor and I’ll be picking up a new power supply and water sensor.
I did notice that the LED light inside the machine wasn’t working anymore so I just unplugged the connectors for now.
Past experience with a 50w the red dot pointer stopped working and caused the same issue which was pulse fire would work and jobs won’t cut. I ended up unplugging the red light and the machine fired away during jobs. Looks like it’s not the same case here but just unplugged it since my work area is well lit.
I would be more concerned with how the supply got in such bad shape. There should be no reason for that if the laser has a proper exhaust system. How are your lungs feeling.
well dummy me I had the sides of the machine blocked off… due to space constraints but I freed it up and now have smooth flow inside the machine. I currently have the same 380 cfm blowers on both machines.
