I recently upgraded to 1.5.02
Twice the laser has stopped running a file for no apparent reason. The first time it was “error 24” I reinstalled the machine setup (GRBL) That seemed to fix the problem but
then I had a similar but worse problem.
The machine stopped moving but the laser stayed on.
Here is the message from the console:
rror:25
A G-code word was repeated in the block.
error:20
Unsupported or invalid g-code command found in block.
ok
error:1
G-code words consist of a letter and a value. Letter was not found.
ok
error:25
error:24
Two G-code commands that both require the use of the XYZ axis words were detected in the block.
This seems strange to me. I believe the “Z” axis should not appear. This machines only works on two axes…
Can you open the file’s Gcode to see if there are commands for the Z axis?
Thank you both. I am not sure if I saved the gcode but I will see if I can find it I will post it. I am in the process of setting up the machine again just to make sure I have it done properly. Then I will do some test runs. If the machine does the same thing I will be back. Either way I will post. I hate it when forums drop the thread without a resolution.
Thanks again
I updated the device and did several test runs with good results and no problems. The job I am trying to do is large image. The final test of the day was going to be 12x12 inches. I was running fine then got this error message:
<Idle|MPos:19.775,19.775,0.000|FS:0,0|Pn:P|WCO:0.000,0.000,0.000>
ok
Starting stream
Layer logo
error:25
On or near line 0:
error:23
G-code command in block requires an integer value.
On or near line 0:
Job halted
Stream completed in 19:28
error:25
ok
error:24
