Laser stopped working on AtomStack S10 Pro
Hello everyone,
i have the atomstack s10 pro but got problem with no blue led !! , i have checked all the cables and there fine , i have checked power and all ok!! the red led is on and machine works but laser is dead !!! lots of money for like 12 times use!!
has anyone had this issue and know what the problem was ?
big thx in advance
Most have an activity light on top. Does it illuminate when it should be working?
Nope it used too be blue led now nothing only a red led (power) .
Then most likely the cable is broken. The fact that they LOOK ok doesn’t mean they are. Those cables break internally at the connector. You can’t see it from the outside, you need to test it. First thing is to fire the laser and wiggle the cable strongly to check if it turns on briefly sometimes.
Thx gonna give that a try when i get home …
Similar issue had s10 pro for 2 weeks only used half a dozen times and laser has stopped engraving, light on top of laser module is blue and very faint light on work surface from laser when going through the motions but nothing engraved, i have used same file and settings as previous jobs that worked fine.
