Laser stopped working Ortur LM3 10W
Laser randomly stopped working after about 20 mins of use from being brand new.
It frames and cycles but the laser is extremely dim.
I played around with power and still the same thing.
Any suggestions on what’s wrong?
Probably bad connection on power side.
How do I test that out?
Check wiggle connections while laser is running.
Can I check it with a multimeter? I bought a new power supply and it puts out 24v, how do I check the laser or board?
Anyone? Anything?
could you send a few image of your wiring images near motherboard
Also at the laser end, do you get both LEDs on?
Yes. All leds on top are on. The pump light and the laser LED.
Hey everyone. Thanks for the replies. The module was bad. Ortur is sending another.
