I don’t know your Laser, but I would start by “beeping” every endstop with a multimeter.
Basically you turn off your laser completely, hook one endstop up to a multimeter, put it in diode mode (Beeping mode) and then it should beep permanently. Then you grab the head and glide it freely over the entire table multiple times, in every possible movement that you can think of. If the beeping suddenly STOPS for a split second, you have a cable break somewhere which appears only sometimes.
However, if it doesn’t, hook it back up to the controller and try it with the other endstop(s) too.
Also be sure that the cables are tightly screwed to the controller.
If your laser has a water sensor, check the cable of it also and make sure it isn’t stalling (if it’s a type of sensor that spins inside).
Also make sure it isn’t endstop interference from lights nearby, microwaves ovens, etc. Putting capacitors in the picoFarad (10pf, for example) range near the controller might solve this issue (if it’s indeed interference - check other things first). If it’s indeed interference, you could build a simple filter or simply buy endstops with integrated filters. If your laser has a DSP it’s very unlikely, as they already come with filers, but just mentioning that too
Also make sure none of the temperature sensors trigger, if your laser has any.
Also check if your power supply isn’t suddenly dropping/spiking power. If it gets particularly hot or if it’s old, consider replacing it.
Also make sure your laser is grounded! This might not seem important, but can lead to interference!
And lastly, if you’re printing over USB, try getting a shorter cable. Longer cables also give interference, especially if the cable isn’t shielded and your setup isn’t grounded!
