Laser stops as if it has finished 4 hr burn and stops at 3 hours
In 90% is a bad USB connection. Try another cable and remove electrical disturbances.
Is it possible to pickup where the laser l let off at? I have the coordinates and have not moved the artwork from the bed with hopes of being able to complete the project.
It’s best if you have the time when it stopped. You can use the preview window, scroll to the position it stopped and then select “start from here”.
Depending on your start-from-position, you might also export the gcode, search for the position, delete everything in front of that and start again. I guess that only works in absolute coordinate mode. And is kind of hacky :slight_smile:
Thanks, I’ll give it a try. Otherwise; I’ll have to start all over.
Again, Thank you for your assistance.
