Laser stops engraving after resuming from pause
Hello,
I recently updated LightBurn to the latest version. Since then, whenever I pause a job and then try to resume it, the laser stops engraving even though the machine continues to move as if it’s working.
Here’s what I’ve tried so far:
I checked my machine settings and verified that the laser works normally during a full engraving without pausing.
My machine is an Ortur Laser Master 2.
The issue started only after the LightBurn update, so I suspect it might be related to a change in the software or settings.
I checked the GRBL settings but couldn’t identify anything unusual.
Has anyone else experienced this issue after updating LightBurn? Are there specific settings I need to check to ensure the laser resumes engraving properly after a pause?
Thank you for your help!
Hello Mooz
On the console window, where it says “type command here”
type
$i
press enter, and paste the full output here please.
It is possible your OLM2 needs a firmware update to fix this issue.
Latest firmware is OLF142
thanks for your answer.
here the output:
$i
[AUTHOR: RenShen]
[MODEL: Ortur Laser Master 2]
[OLF: 137]
[DATE:01:15:16 - Apr 20 2020]
[VER:1.1f.20170801:]
[OPT:VZD,35,254]
Target buffer size found
ok
You will require to update your firmware to 1.42
Contact ORTUR support as I don’t think they have public facing firmware files for the original OLM2
Suppor@ortur3d.com
ok, i’m sending a mail right now. i’ll let you know. thanks a lot
this e-mail is not valid anymore so i send to this one
support@orturtech.com
still no answer yet…
Here it is:
https://cdn.shopify.com/s/files/1/0503/4734/4056/files/olm2-firmware-release.zip?v=1724235520
