Context
I was running jobs without any issue, graving and cutting fine until it started to skip zones (see video attached). Maybe a minor thing but every time I need to engrave or cut, I need to enter the m8 code into the console or the air pump won’t work and the fire laser won’t be shown.
The problem started in the bottom left corner but right now is until the half of the job (vertical and horizontal).
What I did so fat?
• Clean up from dust belts and tight screws.
• Changed the lens for a brand new one.
• Double check wires if some of them are damaged, everything seems OK.
• Unplug and plug again connectors. They look OK.
• Tried on multiple times with different designs.
What could it be?
Thanks.
PS. I’m attaching the video from a Google Drive’s URL. It’s safe.
This is the cause in 99% of all cases. Optical inspection won’t help. The wires are broken internally. You can test by firing the laser and then wiggling the cable to check if it stays on.
Make sure to properly fix the cable next time (after you replaced or repaired it). It’s mandatory.
