Hey All, I think the answer is no but wanted to confirm. Does LightBurn support the FSL Lasers, specifically the Muse with autofocus 3d cam?
Also, Boss lasers supported?
Thanks!
Thanks!
Boss lasers are supported. Stock Full Spectrum Laser systems are not.
From our title page: https://lightburnsoftware.com/
We currently support most Ruida, Trocen, and GCode based controllers. Supported GCode controllers,include Grbl, Smoothieware, Grbl-LPC, and Marlin. Supported Ruida controllers include the RDC6442G/S, RDC6445G, RDC6332G, RDLC-320A, and R5-DSP. Supported Trocen controllers include the AWC708C, AWC608, and TL-3120.
Thank you for the quick reply Rick!
Yep, the Boss should have either a rebranded Ruida or Trocen AWC controller both of which work with LightBurn.
Full Spectrum has a proprietary control system that LightBurn does not work with. People have swapped the Cohesion3D controller I make into other Full Spectrum machines. In the case of the Muse, swapping to any other controller would render the touchscreen, camera, and probably autofocus system useless. Other than their proprietary electronics stack, the Muse has common components under the hood like stepper motors, homing switches, and a Laser Power Supply.
Boss HP machines use the Trocen AWC controller, and Boss LS systems are Ruida based. Both controllers are supported by LightBurn.
