What happened to my origin tabs?
I have no idea and from the words and the picture you shared it is not clear what you are wanting, but I will guess and see how we do.
If you are wanting to restore the window layout back to the way LightBurn looked when you first ran it, select ‘Window’->‘Reset to Default Layout’ from the top menu.
You have full control over window layout and you can drag a window to where you want to set up the LightBurn UI to best suit your workflow. Have a look at this to help in understanding how this works.
I figured it out…had the beginners view selected…
Ah, yep. That would definitely change your view. Glad you got it sorted.
Not sure what I did but my start from has dissapeared…
Did you look at Window from the drop down?
I figured it out…had the beginners view on…
Thanks…now how I turned it off is another mystery…
Pop open the ‘Settings’ window (), ‘Beginner Mode’ is the first option on the upper-left of that screen.
I must have been clicking around one day…thanks for the help…
