Hi all I have a sainsmart 3018-PRO with a sainsmart 5.5w laser got lb all connected and working everything works as it should but the laser doesn’t actually burn anything but will emit a bright light?
Any ideas what’s going on I have no clue we’re to start
Hi mate this is a different machine I brought them. At the same time getting better results with my prover so hoping I can get this working but just getting light even at 100%
The major setting that will affect laser power is $30. That defines the value that represents full power. In this case yours is set to 1000. So in order for LightBurn to know what value to set you need to configure S Value Max in Device settings to match what you have in $30.
But if these already match then something else going on. Is it possible that your speed settings are too high?
Can you confirm that your power is variable? As in 10% is less bright compared to 100%?
How bright the laser is between 10% and 90% doesn’t seem like much I can hardly see the beam with glasses on 90% is brighter but nothing like my other laser
Hmm… that’s odd. Seems like it might be something on the hardware side.
Double check the connectors and make sure everything is plugged in correctly. Are you connected to the red connector on the controller? Make sure the pins on the controller match the laser module.
If all that looks good then try swapping the laser module between your two lasers. If the new laser still has low light then something wrong with the module. If old laser module on new controller doesn’t work well then something wrong on the controller side.
