Laser will not burn image in same place it frames
I am using a FoxAlien Masuter with a 20w laser with the newest version of light burn. When I frame my burn it frames in the correct place (I use stop blocks to place tile and user origin) when it goes to burn the image it goes past the tile and hits the limit switches and never tries to burn. Also when you hit go to origin it wants to go to the home position but when you frame it starts at the set origin. I have a FA Riser and haven’t had any problem with that one.
