Laser will not 'jog'
Hi folks, I’m getting this message every time I try to jog the laser to set up target positions.
“ALARM:2
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection)
On or near line 2:”
Any ideas, Steve
Check to make sure your jogging distance in the ‘Move’ window is set to a reasonable distance - if it’s set too high, even a single jog command could be sending it beyond it’s maximum travel limits, triggering that alarm message.
Spot on! I don’t know how but it was set to like 700 and some inches. I’ve never even looked at it before.
Works fine now. Thank you so much for the help, Tyler. Now I’m burning again. Steve
