Laser won’t fire but frames
My laser will frame but when I tell it to start it either does nothing or travels all way to left and hits frame. I deleted software and reloaded. Restarted computer and laser. In preview window it shows the Red Cross all the way to the left. There is nothing else in the workspace. Using rotary and started laser in home position, then centered over tumbler . Did do Lightburn update last week but as I stated deleted it and reloaded today
I switched to my laptop ( which I did not update recently) and it works fine.
Any suggestions ?
xTool, D1 Rotary? Do you have the Pro version with Limit Switches?
When the xTool D1 first connects, the engraver should communicate the Firmware revision Number. Please scroll back in the Console window, Select the text with the Firmware Version Number (use Ctrl-C) to Copy the text and Ctrl-V to paste the text into a reply here.
In LightBurn, set everything up like you’re about to start, and click File, then Save GCode, and save the file somewhere convenient. You should be able to drag and drop that code into a reply here. Please also let us know if the xTool D1 crashes into the frame or does nothing.
If the Engraver Does nothing, It would be good to know what messages, if any, appear in the Console window.
If your Laptop is still working perfectly, Grab the lbprefs file from it and share it with your desktop computer.
On the Laptop, click File, then Export Prefs and save that somewhere that doesn’t have OneDrive in the filepath. Use a USB stick, memory card or email it to yourself to get it to the other computer (whatever works).
With the file available to you on the desktop computer, click File then Import Prefs and import the file into LightBurn.
D1. No limit switches. RA2 rotary. I will try your suggestions.
Here is console on start up
Waiting for connection…
ok
ok
[xTool D1:ver 40.30.010.01 B2]
M2001 0.0.0.0
[version 2 kokopelli tumbler.gc|attachment]
Here is g code
(upload://msyDaJNLwxnFDPJHYMf8HzrjQSu.gc) (212.2 KB)
Once again it framed but when hit start it hit frame on right side
version 2 kokopelli tumbler.gc (212.2 KB)
