Im a beginner and laser was working fine when i was doing simple test designs and getting familiar with lightburn. Now the laser wont move once it makes 1 move on the x-axis. i tried turning it off and back on thinking it was just a hiccup but once again as soon as i hit the move button to move the laser left or right it just stops and wont respond to anything. my laser is a sculpfun S9.
Done and Done. laser still freezes and has no communication once laser makes 1cm move on x-axis, any thoughts? Keeps stating can not query laser position in machine settings. maybe a software issue with the sculpfun s9?
Just doing basic of all basic etches to learn and get the hang of this diode laser. But every time i hit go the laser moves 1 mm and then stops and freezes and i can no longer get it to move at all. I have to then turn everything off and back on. I can manually move the laser up and down with the arrows in the move box but as soon as i try going right it freezes and no longer responsive.
The parameter $100 is completely off. Set it to 80, not 3200. This will cause moving the motor extremely slow (and it might seem the laser is not responding because it will take ages until it’s finished).
You’re almost certainly not facing the exact same issue. I suggest you create a new Topic and provide as much information as you can about what you’re experiencing, what problem you’re having, what you’ve tried to remedy the problem, and what the results of those remedies have been.
