Hello, I am very new to engraving. The laser wont shut off when it goes from letter to letter ot object to object leaving a trail everywhere it goes. I am Using 15000 mw Blue CNC Laser Engraving Machine from Universal Engraver
i have tried a lot of the suggest in the other chats but have been unsuccessful
Waiting for connection…
Project loaded in 10 milliseconds
Grbl 1.0b [’$’ for help]
Your Grbl may not support Variable Power mode (M4)
If your laser does not turn off between cuts,
switch to the GRBL-M3 device
ok
[1.0b.20150902:]
ok
$0=10 (step pulse, usec)
$1=25 (step idle delay, msec)
$2=0 (step port invert mask:00000000)
$3=0 (dir port invert mask:00000000)
$4=0 (step enable invert, bool)
$5=0 (limit pins invert, bool)
$6=0 (probe pin invert, bool)
$10=0 (status report mask:00000000)
$11=0.010 (junction deviation, mm)
$12=0.002 (arc tolerance, mm)
$13=0 (report inches, bool)
$20=0 (soft limits, bool)
$21=0 (hard limits, bool)
$22=0 (homing cycle, bool)
$23=0 (homing dir invert mask:00000000)
$24=25.000 (homing feed, mm/min)
$25=500.000 (homing seek, mm/min)
$26=250 (homing debounce, msec)
$27=1.000 (homing pull-off, mm)
$30=1000. (rpm max)
$31=0. (rpm min)
$32=1 (motor lock bool)
$33=7 (motor mode mask:00000111)
$100=80.000 (x, step/mm)
$101=80.000 (y, step/mm)
$102=80.000 (z, step/mm)
$110=10000.000 (x max rate, mm/min)
$111=10000.000 (y max rate, mm/min)
$112=10000.000 (z max rate, mm/min)
$120=250.000 (x accel, mm/sec^2)
$121=250.000 (y accel, mm/sec^2)
$122=250.000 (z accel, mm/sec^2)
$130=500.000 (x max travel, mm)
$131=500.000 (y max travel, mm)
$132=500.000 (z max travel, mm)
ok
It says i am running with GRBL 1.0b… where can i get one higher if i need it?
And you will notice at the top of the console read out it says “Your Grbl may not support Variable Power mode (M4) If your laser does not turn off between cuts, switch to the GRBL-M3 device.” Which is what the machine is doing but I cant find in my research how to change to M3???
