LaserGRBL cuts, Lightburn doesn't
New to Laser hobby, Have a new Atomstack A5 M50. I’ve successfully run the LaserGRBL cutting test. with 3mm birch plywood with best result settings at speed F450, power S1000, and 5 passes. Using trial version of Lightburn, I have so far been unable to successfully cut same material (in fact, same test board), using the Material Test setup. Power set to 100%, speed ranges from 200 to 500, and up to 8 passes. There must be a setting I am missing? Is the laser not getting the full 100% power setting? I.E. I am not seeing the equivalent of setting “S” to 1000. Otherwise, I really like Lightburn and its UI and features. Planning on purchasing IF I can resolve this cutting issue.
Thanks in advance.
Your set to mm/min in settings and s-value of 1000 in your device settings?
Here is a screen shot of the Lightburn test…
Are there other settings I have missed?
Edit > Device settings
can you take a screenshot please?
Hmmm - Just noticed S Value max is set to 255! I suspect THAT is my issue!!!
Seems you had this profile as M3 first, then changed to GRBL
This shoudl be 1000
Thank You! Always helps to have multiple eyes!
I just hope I will be able to pay this forward.
