Lasering Acrylic Neje LaserMax 4
I have cast and moulded Acrylic but cannot laser either. Would anyone know the settings to use? 3-5mm Acrylic. The cast one has a film which can be removed. Laser just goes straight through onto whatever is behind/underneath the acrylic. Tried Blue masking take on top and underneath. No joy.
If you have a diode laser, you won’t have any luck with acrylic. The wavelength just doesn’t suit transparent materials.
With a diode laser, you can only use dark & opaque acrylics. Everything that is transparent for the human eye is transparent for the laser as well. No energy is absorbed. It’s a physical thing; no way to circumvent this.
Blue acrylics also don’t really work; the main colors are black, red, and green. Everything else is dependent on the actual laser power and energy absorbed. There is special laser acrylic where also some brighter colors can be cut. But it’s usually pricier. White and clear are still a no-go then.
I did this June 2024, 3mm acrylic,
with a 10w diode. But I think blind dumb luck played a bigger part than skill.
Cheers for that, I can give up now, the thought was nice while it lalsted.
You will find there is a lot of Trial & Error in this hobby :heart_exclamation: :rofl:
I did have some success with dual colour acrylic
Cheers, I’ll stick with the dual coloured acrylic
Other than the shadow of your head on it, it looks really good. :rofl:
Really, it does look good! I have not tried 2-color yet, but seeing your work gives me some ideas. Thanks for sharing!
Update to red acrylic cutout with 10w diode:
  1. 200mm/m
  2. 95% power
  3. 3 passes
  4. Constant power
  5. Air Assist
  6. Sitting on honeycomb
  7. 300mm x 100mm sign
  8. About 1/2 hour run time
What is that top layer color? I kind of looks like silver.
It’s Gold on Black.
Mind sharing your power, speed and LPI settings? I can put my laser in the 20w setting, and hopefully it will look as good as yours.
If you look at a color wheel, the color opposite of your lasers ‘color’ will give you the color that will absorb the most, what you want for cutting or engraving.
You’re doing well with red, which indicates you must have a green laser?
:grinning_cat:
It looks blue to me, but I am no expert. :rofl:
I like that color chart, I saved it.
Will do when I get home later.
Looks Blue, glasses are red, I’m no expert.
1.6mm Laminate Brushed Gold/Black Core - 600 x 400 mm
LaserMaterials.ie
I see those sheets as 12" square online. Also, do you do a cutout as well? If so, settings for that too.
I understand these will just be ballpark numbers for me, but I know peeling off that first layer will be critical. :grimacing:
