2,5 watt Eleksmaker
Using scrap pine
2 coats of flat white sand with 220 in between
one final coat flat white,sand
1200 mm/min,40% power 318 DPI
with the flat white paint you can use sharpies to add colour
Hey Bulldog, what program are you using to produce the final image before sending them to the laser?? Photoshop, Photograv??? cheers Denzill
Paintshop Pro 19…resize clean-up…then sometimes with LightBurn I use gamma/contrast in shape properties
Every photo is different
Did you use masking tape (since you used white paint)? And did you use a negative or positive of the photos? Thanks!
