LaserPro Compatibility
I’ve gotten Lightburn to mostly work with LaserPro by adding a short start and end script. This works pretty well except for roller mode. Is there anyway to configure Lightburn for roller mode for LaserPro short of manually editing the Gcode file generated by LaserPro? The roller command for LaserPro is C followed by the roller position.
Can you explain what roller mode is and how it works? Where would the command need to be placed and under what conditions?
“Roller Mode” should be the rotary mode with a “roller” (used to engrave round parts like cups).
Did you already go into the “Tools → Rotary Setup” menu and select roller and check if “Enable rotary” is on?
Yes. It doesn’t enable the rollers on the LaserPro and doesn’t appear to change the GCODE. Is there another setting somewhere I’m missing?
