You have not yet added the LastPass tool to Profile. With this tool the cut is very clean. This is a big delay for someone who uses the Router professionally and has to Copy - Paste to give -0.2 on the second pass. Is there any plan to add it?
you could try this in depth per pass
say your final depth is 6mm in depth per pass type 6 - 0.2 TAB
that will give you a 5.8mm pass and than a 0.2 pass
if you than run preview it will run your 0.2 as your second pass
there is a section in the docs which explains this but i cant think which section
this vid might help
I explained this before, what I’m doing is a copy of the first pass with -0.2, that is, two Operations with the same cutting tool for one object.
Maybe the final last pass option would be linked (Kinda) with the ‘planned’ lead in/lead out ![]()
That is correct. We have a lot going on and not every feature is going to get finished instantly.
You don’t need to do that - If you do what Terry suggested it’ll just work.
For example, if your material is 12mm thick and you want 4 “normal” passes and one very thin final pass, it’s just:
12mm/4 = 3mm pass depth, minus a tiny bit so it’ll do an extra last pass:
If you did 2.9mm passes, the last pass would be 0.4mm (the missing 0.1mm x 4).
It will get added, but we’re juggling a lot of work between MillMage and LightBurn releases, and bug fixes are being prioritized over new features.
