I have been using LB for a few years now. The last time I used it was spring of 2025. When I tried to use it in the fall, I needed to updated the software. Ever since that update LB has not worked right. Now I could laser engraved flat work ok. But when I tried to use rotary I could not get it to frame or engrave properly. With holidays and afur
You did not need to update, Lightburn has a forever license. You only need to update to get the new releases. You can roll back to your working version by simply reinstalling it. If you do that and the rotary still does not work, then you have a rotary settings issue.
And you can go back and re-load spring 2025 preferences, with either the rolled back version or the new version.
