I am currently lasing four identical works in 1/8inch walnut. First ran perfectly, although another pass would have ensured complete burn-through. Installed latest update, as I always do when I get notification. Second board, 4 1/2 hour run time, partway through the laser glitched but without stopping, continued program cutting wrong paths over and over, completely destroying the board. How do I revert back to the last update?
A glitch is a technical malfunction that usually corrects itself, which yours doesn’t. Which makes it more difficult to find out what happened.
Did you export/import your settings from the old/new installations?
Your symptoms are more like you’re losing steps when it moves to new locations. This it more like a controller issue than Lightburn issue. I’d suspect the connection, especially with USB. If you have a dsp type, like my Ruida then an lan connection works best.
Maybe you can tell us more about what you’re doing at the time of the fail. I’m assuming scanning operations, but I don’t know. This is usually where good diagnosis steps shines..
You can post what your doing when it fails along with acceleration values. A screenshot of what it shows in preview and your actual results. Most of us use their phones. ![]()
I believe you can load multiple versions on it. Then you could switch back and forth. You could try searching the document section for ‘multiple’.
