I would like to know if there is an easy way to select a certain group of objects to change the color.
I made an example that follows the image.
Let’s suppose I want to change the color of the squares.
Is there any way to select this color group using the cut and layer layout or do I have to select them one by one.
Hold down the ‘Shift’ key while clicking on the layer in the Cuts/Layers window.
See our documentation here.
If the squares are all on the same layer, hold shift and click the layer name in the cuts/layer window. That will select everything on that layer.
Thank you very much.
