I have read through some of the questions about naming layers. It seems that the name is stored both in the project and also in some default area within LightBurn. When you start a new project, the layers names are set to what the last project had for names, at least for the layers that it uses.
Is there an easy way to reset all of the names back to some default setting C00, C01, C02… or do we just live with the names we use in one project in all projects?
After naming each layer in an early project based on the power level I used for each layer, I did go through and name them all back to C00, C01, C02… But that was a waste of time when I loaded the power test project again and the names went back to 100%, 90%, 80%,… Seems like a never ending cycle of naming layers.
And now, even if I don’t save this original project in this example after reopening it, the layer name will default back to GlueGuide on any subsequent new project. That is until I open a different project having a different name for that layer where that layer name then becomes the new default.
