Hi,
I have noticed that when you have layer with image and other vector layers. If some layer has sub-layers, in Cut Settings Editor Output Sub-Layer toggle is not showing after clicking on layer which has image. Cut settings editor should be closed and opened directly from some of vector layers to display ‘Output Sub-Layer’ option on it. Clicking on vector layers is working OK, only image layers are messing up.
It is not related to 1.5, 1.4 has also same issue.
I have attached sample project to reproduce. If you open cut settings editor for ‘Vector’ layer, ‘Output Sub-Layer’ is visible. If you click on ‘Image’ layer and again on ‘Vector’ layer, ‘Output Sub-Layer’ toggle is not visible anymore.
lbrn - sublayers demo.lbrn2 (247.1 KB)
