Layer Z offset, bed moves at end of layer, returns to z=0 before next layer
I am attempting to defocus for thicker vector lines. As you can see in the video, the bed only moves at the end of a layer, then returns to zero before cutting the next layer, so all of my layers are actually cut at z=0. I would like them to cut at z=2,z=4,z=6,z=8…z=22
At the end of the job, X and Y return the the starting position while the Z remains at 22mm.
z-height.lbrn2 (45.3 KB)
  • BesCutter Versa Force 150W CO2
  • Ruida RDC6445 controller
  • Lightburn 1.0.0.6 on macOS Monterey
  • Lightburn Bridge 1.0 rc4 image on an RPi 3
The video shows the above file run with these device settings.
When I turn off “Relative Z moves only”, the bed does not move. It stays at Z=0.
Optimize Z moves doesn’t seem to affect the behavior of my machine when running this file.
I don’t know a lot about Ruida controllers, so I took photos of every menu that seemed related to Z travel or focus. These may not be related to my issue.
Anyone? I really need to get this working.
How are you setting the Z height? That’s not clear from your post. Can you upload the .lbrn file here?
https://forum.lightburnsoftware.com/uploads/short-url/g0MTkISzSN6pHv3acQE5yv5QBg8.lbrn2
I’m setting the z offset of each layer
Okay. The video is clearer now based on that.
One thing I’m noticing in the setup is that you have a material height of 0 mm but looks like you have a positive Z offset. This would imply that you’re trying to go into the material which has no depth.
I’m guessing your intention is to increase the distance from the lens which should be a negative offset. This is also likely the reason why there is no movement when you don’t have “Relative Z moves only” selected since absolute moves are based on material height.
