Hi , very very new to this laser stuff and I’m trying sort things out, I am using one computer to set everything up in light burn and then copy g code to jump drive. Then I take it to the laptop connected to my laser, atomstack x20, The problem is that the layers and speeds and power setting don’t load from the jump drive, I’m sure its something I’m doing wrong but I’ve looked through the forum and don’t see a solution , thanks for any help I can get.
If you want to transfer a project, save the project using File-Save As (or Save). It will save to the native LightBurn .lbrn2 (or .lbrn) file format. Copy that file to the USB drive. Transfer to your other computer and load there.
The native LightBurn project file will store your project graphics and settings.
In addition to transferring the LightBurn project file, you should also set up both LightBurn instances so they have the same preferences:
That’s a one-time event, assuming you won’t change the device parameters on one of the installations, and will eliminate many questions about why LightBurn looks or behaves differently on the two machines.
Thanks I will give that a try, sorry about the long response time, life is very busy right now. thanks again!
