Colleagues,
It’s ok what Lightburn not stored layer sequence?
I have some template for make new cuttings. And in this template I stored serval “Cuts/Layers” with settings. I need first run C03, next C01 and finally C00. I put this layers in this sequence and everything work as I need!
Next my step is remove all objects from template and import new objects from SVG.
And in this moment I have strange problem - all layers (in "Cut/Layers window) restored in alphabetical order. Not in stored previously order.
And I need restore my order every time after this operation!
I found solution - if I first import SVG and after it remove old objects - order of layers not breaking.
But this is not convenient.
Am i doing something wrong?
