Layers with "output" and "show" toggled off shouldn't be considered when using user origin
If you have a situation like this
I would expect Lightburn to ignore the shapes on layers that aren’t marked for output. In fact, even if you have the layer marked to not output and also not even show, it still uses it for user origin as shown here
Is this intended behavior?
If you enable ‘Cut Selected Graphics’ and ‘Use Selection Origin’, you will get the behavior you are after.
This is absolutely intended behavior - People often need to re-cut specific parts of a job, so the origin calcs don’t change just because you turn off a layer. Cut Selected is the correct way to get what you’re looking for.
Exactly, I use a 'Don’t output layer" as a reference most of the time.
