for some reason when im running my lazer its drawing double lines
Hi Casey,
This sort of double image production is most often attributed to loose components in the motion system of your laser, on the affected axis. I would suspect that your x axis had a loose belt, loose pulley on the motor that drives the X axis, or a loose diode mount.
Please do a physical once-over of your machine and check that the belts are taught, and that everything is solidly affixed in the machine.
